Activity Forums Adobe After Effects Expressions Calculating angle from camera to object – expression
  • Calculating angle from camera to object – expression
    Posted by Joemason on November 8, 2006 at 8:16 pm
    I’ve been trying to figure out a way to calculate the angle between an 3D layer and a camera… specifically, a perpendicular line from the center of any given 3D object and a camera.
    The first idea I had was parenting a Null to the “object”, having it auto-orient to the camera, then calculating the absolute rotation of the Null. But in 3D space, this seems to be a tall order.
    Mainly this is to adapt Angle property controls based on camera/object angle.
    Anyone have any great ideas?
    Colin Braley replied 19 years, 10 months ago 3 Members · 4 Replies
  • Dan Ebberts
    November 8, 2006 at 9:47 pm
    It’ll probably be some variation of something like this:
    C = thisComp.layer(“Camera 1”);
    v1 = normalize(position – C.position)
    v2 = C.toWorldVec([0,0,1]);
    radiansToDegrees(Math.acos(dot(v1,v2)))
    Dan
  • Colin Braley
    November 8, 2006 at 11:32 pm
    Dan,
    I was reading through this expression trying to figure out how it works and ive got a few questions. I typed out what I think each line does but im not sure about line 3…
    //var C = the camera
    //v1 is the direction vector from the camera to the layer (it has length 1)
    //what is this line doing?
    //so here you are finding the angle between v1 and v2 and outputting it in
    //degrees because v1 dot( v1 , v2 ) = length(v1) * length(v2) * cos( theta )
    //where theta is the angle between the two vectors…but since v1 and v2 are //normalized you are just using the arccos to get the angle between the two //vectors
    Thanks in advance Dan.
    ~Colin
  • Dan Ebberts
    November 9, 2006 at 2:00 am
    Colin,
    Your analysis is dead on.
    This just creates a unit vector in the direction of the camera’s z axis and translates it to world coordintes. Then you have the two unit vectors you need to find the angle.
    Dan
  • Colin Braley
    November 9, 2006 at 2:17 am
    That makes sense now…thanks a lot Dan. I’m taking a class in vector geometry and 3d calc so a lot of the expressions you have up here finally make sense to me… 🙂
    ~Colin
