Activity › Forums › Apple Final Cut Pro Legacy › Calculate Amount of Footage in Project
  • Calculate Amount of Footage in Project
    Posted by Max Carlson on July 27, 2009 at 2:35 am
    I have a project with many hours of footage loaded in, split over many different files. Is there an easy way to tell how many hours of footage my project contains?
    Lisa La rosa replied 16 years, 5 months ago 8 Members · 9 Replies
  • 9 Replies
  • Teague Fleury
    July 27, 2009 at 2:45 am
    I actually was just checking my footage today to see how many GB’s were in one minute of HDV capture.
    I assume you are using FCP, so open the project file folder and go to the capture scratch folder. Open it and you should have all your footage that you captured inside this folder (or multiple folders depending on how you captured the original footage). The next part is tedious but shouldn’t take more than 10 minutes. Just right click on each file and select “get info”. There is a line item in get info that shows duration. Just get a calculator out or a piece of paper and write down the duration for each file. Add it up and that will give you your total minutes/hours of footage captured. Hope that helps.
    Teague
    NOMAPSfilms.com
  • David Roth weiss
    July 27, 2009 at 2:46 am
    If you tell us how many gigabytes of drive space it takes up and what video codec you’re editing, we can help you to calculate the hours of footage you have.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Andy Mees
    July 27, 2009 at 3:56 am
    try this: with the project tab active, press Cmd A (for Select All) then Control C (for Batch Capture)
    at the bottom of the subsequent Batch Capture window you should see a summary for Total Media Time (and Total Disk Space).
  • Zane Barker
    July 27, 2009 at 4:20 am
    I believe that media manager will tell you how much space all the assets in your project are taking up.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Zane Barker
    July 27, 2009 at 4:34 am
    Oh and for got to say that once you know how many GB of space the project is taking up just to the math for how the duration of the footage vs file size based on the codec you captured in.
    You can use the AJA Data Rate Calculator Application to help you figure that out.
    https://www.aja.com/products/software/
  • Max Frank
    July 27, 2009 at 6:59 am
    DH have a great free video calculator widget:
    https://www.digital-heaven.co.uk/videospace
    W
    MBP 2.4 – 10.5.6 – FCP 6.0.5
  • Stuart Simpson
    July 27, 2009 at 3:22 pm
    Or there’s an online version of the widget here:
    https://www.videospaceonline.com/
    -Simmie
    6 MacPros – Kona 3 & Kona LH
    1 G5s – Kona LH
    xbox360, Wii, PSP, PS3
    https://www.speak.co.uk
  • Lisa La rosa
    October 12, 2009 at 4:07 am
    Here is a really quick way to do it:
    Put all your clips into one bin or folder, use the find function if you don’t want to actually move them.
    Select all the clips and then right click (or control click) and scroll down to Media Manager.
    In Media Manager, under the “Media” option use the drop down menu to select “Copy”.
    Hover your mouse over the “Modified” green bar till it highlights, under the green bar the total media length and file size will magically appear.
    Ta Daa.
    When you are done just cancel.
  • Lisa La rosa
    April 21, 2010 at 4:12 am
    Ta Daa.
