Activity › Forums › Apple Final Cut Pro Legacy › Cal Digit Hard Drive dropping frames when capturing
  • Cal Digit Hard Drive dropping frames when capturing
    Posted by Codri Albeanu on May 4, 2009 at 5:03 am
    Caldigit drive is connected via firewire 800 (camera as deck is connected by FW400) and set up as RAID 0. (and yes scratch disk is set to Caldigit drive and i did set drive to MAC OS Extended in utilites)
    I am capturing on a Mac G5 in FCP studio- external hard drive is a Cal digit VR, 2TB set at RAID 0- When I try to capture SD footage from a mini DV tape (Panansonic camcorder as deck) the capturing starts just fine but then it rewinds back to cue the In point again-and then stops capturing with a dialog box stating “dropped frames detected on last capture.” I have tried several tapes from this production and this happens consistently.
    It looks like its the new Cal Digit external hardrive (hooked with a FW800) I tested the tape with a less expensive Western My Digital external drive and i am not having a problem at all. Previously I transferred data using firewire daisy chained MyBooks (less quality drives) and did not have this problem– is this new more powerful Cald Digit drive more demanding (on the FW port)?
    Thank you
    Codri Albeanu replied 17 years, 4 months ago 6 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    May 4, 2009 at 4:04 pm
    Call CalDigit. They have great tech support.
    Shane
  • Jon Schilling
    May 4, 2009 at 5:01 pm
    Codri,
    In an effort to help, we are wondering if you’ve enabled “turbo mode”
    https://www.caldigit.com/KB/index.asp?KBID=25&viewlocale=1
    You’re welcome to call us for support, also, so that we can gather more information to solve your issue.
    Thanks.
    Jon Schilling | Director of Business Development
    CalDigit Inc
    phone 714-572-9889 X234
    fax 714-572-9881
    web http://www.caldigit.com
    email jons@caldigit.com
    skype cgijon
    office 1941 Miraloma Ave. #B Placentia, CA 92870
  • Scott Davis
    May 4, 2009 at 5:28 pm
    Second that wholeheartedly!! CalDigit will do whatever it takes to get you going. Can not recommend them highly enough.
    Scott Davis
    View Scott Davis's profile on LinkedIn
  • Jeremy Garchow
    May 4, 2009 at 6:51 pm
    It is usually best practice to separate your video input from your storage input. If you put your fw400 camera on a separate bus than your fw800 storage, you will probably get the necessary throughput for capturing.
    Jeremy
  • Codri Albeanu
    May 4, 2009 at 10:34 pm
    Thank you- I’ve called Cal Digit and they recommended some of the troubleshooting mentioned above.
    Codri
    CA
  • Codri Albeanu
    May 10, 2009 at 7:07 pm
    Hello John- Thank you for your response- I have tried turning on turbo mode following the instructions below, provided by a very helpful CalDigit tech support person
    -eject Cal digit from FW
    -push right buttonb ( wait for “Loading”)
    -go to third choice” Miscellaneous Configuration”
    -“file manuals”
    -Turbo -OK
    but when i went set it the “file manuals” choice with “turbo OK” selection does shows up on LCD screen- only “beeper off/on” and “turn on cfg default”
    Not sure what to do next to turn on the “turbo” option which was recommend as a solution for dropping frames /capture problem with this drive
    Thank you
  • Codri Albeanu
    May 10, 2009 at 7:52 pm
    How do I separate these? Ddo i ned a PCI card with FW ports? This would be for a MAC G5 3 years old. Thank you
