Activity Forums Maxon Cinema 4D CAD DXF DEBACLE
  • CAD DXF DEBACLE
    Posted by Glenn Takakjian on May 10, 2006 at 1:13 am
    So, I have tried on numerous occasions to get files from CAD programs and bring them into C4D. I ask for DXF files. They send a file that looks suspicious like an Illustrator file (from the icon) and I try to import into C4D… Wrong file Format. Try to open with Illustrator … it just locks up.
    Does anyone know if it is possible to get CAD files to integrate with C4D… It would save me days of model building if I can open this file
    TAK
    Glenn Takakjian replied 20 years, 3 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    May 10, 2006 at 4:52 am
    Make sure to ask for dxf 12, and ask them to purge the document of xrefs etc. If you are getting 2d cad plans from Acad, ask them to explode lines before exporting.
  • Glenn Takakjian
    May 16, 2006 at 11:35 pm
    For full 3D interface…. We managed to get some decent results with .obj exports. It comes across in millions of pieces… has to be connected, optimized and re-phonged.. but it works.
    Also, there is a strange case of redraw… I think it is a depth of field check box but I can’t seem to find it.
    As I zoom in and out, parts of the objects disappear (Gourad or Quick Shading)
    Thanks for the info.
  • Daniel Moore
    May 23, 2006 at 8:46 am
    I do this routinely via .wrl format (VRML). Lots of issues with solids importing unless they are converted to mesh first, then none at all. If it’s an option give it a whirl.
  • Glenn Takakjian
    June 20, 2006 at 6:00 am
    I will try this next time… thanks
    TAK
