Activity › Forums › Maxon Cinema 4D › Cached cloth simulation doesn’t work with motion clip
  • Cached cloth simulation doesn’t work with motion clip
    Posted by David Cabestany on May 16, 2014 at 3:55 pm
    I have 4 cloth simulations on my scene, and I cached them so I can offset their time as needed, then I’m throwing the objects along with a camera and a motext object inside a null and adding a motion clip tag to it so I can retime the entire animation, everything gets retimed fine except for the cloth simulations. Is there a way to have them included in the motion clip?
    Thanks.
    David.
    David Cabestany replied 12 years, 4 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    May 17, 2014 at 4:51 pm
    Works fine here. Did you check “bake expressions” and “PLA” when you created the motion clip?
  • David Cabestany
    May 19, 2014 at 3:59 pm
    Hey Adam,
    I did. I first tried without it and then with it, I also tried with one or the other and everything gets sped up but the cached simulations.
    I’ll try it one more time from scratch to see what happens then.
    Thanks.
