Activity Forums Adobe After Effects Cache speed rules all, correct? Also, is my build on-point?
  • Cache speed rules all, correct? Also, is my build on-point?
    Posted by Michael Menefee on March 7, 2017 at 9:19 pm
    This post could be in the Premiere Pro forum but After Effects always seems to be the most taxing.
    I am looking at buying a new desktop and want to be sure I am planning things out correctly. Here is the build:
    https://www.cyberpowerpc.com/saved/1JKNET
    I already have a mass/backup storage in a 4TB drive. As you can see in the build link, I am looking at buying an M.2 SSD and an EVO Pro. I am thinking I would put OS on EVO and then use the M.2 SSD for the cache, keeping all of my project files and video files on the 4TB drive.
    Yes, the 4TB drive is the slowest of the three but AE or PP wont be using that drive once I place in-project because it creates a more readable version of the file in the cache, correct?
    Tim Drage replied 9 years, 6 months ago 2 Members · 3 Replies
  • Michael Menefee
    March 7, 2017 at 9:58 pm
    PP aside for a second, I would still like an answer related to AE. Does cache rule?
    Back on PP, it has cache settings much like AE when I go to Preferences>Media. What is the difference?
  • Michael Menefee
    March 7, 2017 at 11:21 pm
    Thanks Dave.
    It comes down to a bit of laziness and a lot of workflow. I have to maintain every file I shoot/receive. That means I have a lot of files and they need to be safe. I bought the 4TB external RAID for just that.
    I dread moving files from one drive to the next each project.
    The external RAID 1 tests at 158 MB/s sequential read and 129 MB/s sequential write. Not even close to an SSD but, I think fast enough for even 4K video.
    After all, the “best” drive setup needs 3 SSDs (1. OS/Software, 2. Project files, 3. Cache). That means I need to spend even more on my already expensive build…… PLUS the pain of moving files.
    Sure, having project media on an SSD would be best/better. But as long as the external RAID 1 doesnt bottleneck everything (seeing how OS/software is on SSD and cache is on very fast M.2) I think I’ll be okay. I can always add an SSD at a later time.
  • Tim Drage
    March 8, 2017 at 1:47 pm
    cache speed would rule more if the caching in AE actually worked properly and didn’t need clearing every 5 minutes to troubleshoot inexplicable problems, or turning off entirely to get certain shots to render at all without crashing :-/
    but yeah put it on the fastest drive you can, that way when it’s working it will be fast ,and when it’s not you won’t have to wait 10 minutes for GBs of cache to be deleted 🙂
