Activity › Forums › Adobe After Effects › cache on external vs internal ssd?
Posted by Ben Wolfinsohn on July 9, 2014 at 1:09 amI’m running a 2.8GHZ i7 macbook pro with 16GB ram and SSD drive. is it better to run your cache files on a external thunderbolt with ssd or is the internal fast enough to not make a noticeable difference?
thanks
benDavid Cabestany replied 12 years, 1 month ago 4 Members · 3 Replies -
Ericbowen
July 9, 2014 at 3:12 pmThunderbolt is fast enough for the SSD drive. I would suggest getting a big enough SSD to handle the cache and media files if you do that though.
Eric-ADK
Tech Manager
support@adkvideoediting.com -
Walter Soyka
July 9, 2014 at 3:16 pm[ben wolfinsohn] “I’m running a 2.8GHZ i7 macbook pro with 16GB ram and SSD drive. is it better to run your cache files on a external thunderbolt with ssd or is the internal fast enough to not make a noticeable difference?”
The internal SATA bus will be faster than a Thunderbolt-to-SATA adapter, by probably 10-20% in the real world.
You may choose an external drive anyway for more capacity.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
David Cabestany
August 5, 2014 at 2:55 pmMy imac has a 256gb internal ssd drive and a 2tb 7200 rpm drive, I keep the software and cache on the ssd but lately I’m running out of space and I’m always getting a warning about my cache folder not having the specified amount which is around 60gb, should I buy an external thunderbolt ssd drive and levea it exclusively for cache?
I was looking at an Elgato ssd thunderbolt 240 gb but there’s a few complaints about the drive dying after a while.
Can anyone vouch for this drive or recommend a good, reliable and fast drive for cache files?
Thanks.
