Activity Forums Adobe Encore DVD Cache files
  • Cache files
    Posted by Mohamed Alami on February 16, 2007 at 2:56 am
    I’m using ENCORE DVD2 and my project size 3.6GB I had less than 40 GB free space, I tried to build image file, it took over an hour building at the end I got error volume is full. I checked space on hard drive I found it full.. I’m freeing more space on hard drive,,, but I noticed that the size of Cache file inside the source file is 34.6 GB
    my question is can I delete the cache files.. and would that affect my project. I often get out of memory error.
    would I save more space if I build dvd direct to disc. please.
    thanks
    Moe
    Mylenium replied 19 years, 7 months ago 2 Members · 3 Replies
  • Mylenium
    February 16, 2007 at 7:40 am
    Have you considered transcoding the sources first? Encore will place backup copies of your original files in the source files folder plus MPEG-II transcoded versions. That’s of course going to kill a lot of free space.
    Mylenium
    [Pour Myl
  • Mohamed Alami
    February 16, 2007 at 10:23 am
    ok, i will try again, and transcoding the sources first, but..is it ok to delete the cache files,,, as they are so big 44.2GB.
    and if its ok,, should I delete the whole of cache file or delete Media Cache Files which it is inside the cache file.
    thank you
    Moe
  • Mylenium
    February 16, 2007 at 8:26 pm
    Only delete the media cache files. Don’t tamper with the xml files and the other small files. Encore is able to rebuild a DVD even without them, but some things might get lost (chapter markers, overrides).
    Mylenium
    [Pour Myl
