Activity Forums Apple Final Cut Pro Cache file memory question
  • Cache file memory question
    Posted by Jonny Cates on December 22, 2022 at 6:33 am
    I bought a 1 TB solid-state external for my 12in laptop that has Final Cut Pro 10. I shot about an hour and a half stage production in 1920 x1080, and thought that I had set up this drive to hold the entire project from this one show.
    I must have NOT selected something properly, because the cash file from this show was saved in the Movie folder on my laptop. Everything else went to the external.
    Consequently, the Movie folder now takes up around 49 GB (specifically the cache file folder) and of course I got the warning:
    “run out of memory.”
    I had about 50 GB available on that drive.
    I thought I had a preferenced everything to go to the new external TB.
    Question is, I’m not certain how to move the cache files from my laptop to the TB external.
    Or even more so, what should I have selected in the beginning (before I imported the footage) to make certain my laptop wouldn’t get any files from this project and that it would ALL go on the new external?
    And just what is the safest way to move this cache file folder to my external— and then delete the old cache folder on the laptop to free up space?
    This project needs to be finished before the end of the year. This was shot on December 11, 2022.
    Thanks so much…
    Jonny
    Jonny Cates replied 3 years, 8 months ago 2 Members · 4 Replies
  • Ben Balser
    December 22, 2022 at 12:22 pm
    A few things to check here. First of all, make sure Background Rendering in your preferences is turned off (leave it off). Next, verify the settings for that Library. Select the Library in the Browser, go to the Inspector, for “Storage Locations” click the Modify button, verify what’s set up there. Make any changes you want to there. I’d also highly recommend getting a copy of Final Cut Library Manager and use it to manage various things, keep your disk space cleaned up. As for where to put your cache for the Library, keep it on your external drive, no need to split everything up on different drives. There are those who will argue you must, as a retired IT engineer, I’ll argue you don’t have to, unless you’re using a very, very old Mac on very old versions of the apps.
  • Jonny Cates
    December 23, 2022 at 7:55 am
    Thanks Ben….i know where I made the initial mistake now after your answer to me. Since Covid, I’ve been away from editing for a couple of years and some of my memory needed jogging.
    Lastly, Im getting this question after selecting my cache file to go to my external.
    Do I need to include these cache files because it sounds like it’s going to copy the same files to my external.just wasn’t sure if I should click include or don’t include.
    Thanks again for your reply Ben.
    Jonny
  • Ben Balser
    December 23, 2022 at 2:24 pm
    Sure, why not? Keep everything together! Sure! Do it!
  • Jonny Cates
    December 23, 2022 at 3:41 pm
    Thanks again Ben….will do!
    -Jonny
