Activity › Forums › AJA Video Systems › Cable to convert the 2 channel AES to two mono analoge XLR’s
  • Cable to convert the 2 channel AES to two mono analoge XLR’s
    Posted by Chris Armstrong on August 15, 2008 at 10:05 pm
    Does anybody know of a cable or a cheep converter that would convert the Kona’s 2-channel AES XLR cable to a pair of single analogue XRL’s that I could plug into a mixer.
    I only want to monitor channel’s 1 & 2, and would like to plug the xlr’s into my Mackie mixor.
    Bob Zelin replied 18 years, 1 month ago 3 Members · 2 Replies
  • Don Wilson
    August 16, 2008 at 6:05 am
    Much cheaper to but the breakout box.
    Don Wilson
    donwilson.tv
    AmericanaMediaInc.com
    MississippiSon.com
    818.660.2915 studio
    818.207.6924 cell
    818.760.1828 fax
  • Bob Zelin
    August 17, 2008 at 3:48 pm
    Don is correct. You did not specify if you have a Kona 2 or Kona 3 (if you had a Kona LH or LHe, it has analog audio out). Both the Kona 2 and Kona 3 offer the K2 or K3 box, which have analog audio out, to go to your Mackie mixer, for about $259. Most AES/EBU to analog converters cost more money than this. The exception is the Behringer SRC2496, which is around $129. But with the K3 box from AJA, you get a nice breakout panel, instead of that mess of wires, so it really is worth the money.
    Bob Zelin
