Activity Forums Adobe After Effects Cable tail
  • Cable tail
    Posted by Gigi Marzo on July 1, 2015 at 9:50 am
    Hi… Im back again. 🙁
    I have new dubt/problem. Is it possible that I cannot create/animate a cable that perfectly follow an object?
    I tried it by the stroke effect with a mask, I tried to import the illustrator file and use the puppet tools, and also I followed the tutorial “cg snake”.
    So I have a headache!
    If you want to better understand, take a look at the project. 9008_cable.zip
    Im apologize for my little english and for not being clear enough. I’m really mortified to be always looking for help.
    Meanwhile, I begin to understand just be scant.
    Thank u in advance.
    Gigi Marzo replied 11 years, 1 month ago 2 Members · 2 Replies
  • John Cuevas
    July 1, 2015 at 1:31 pm
    Check out this tutorial, maybe it might help you out.
    How To Make A Wiggling Cord From Particles
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Gigi Marzo
    July 9, 2015 at 9:21 am
    hey!
    I have solved by using the puppet too and following a little bit this tutorial
    I hope it can serve to someone else!
    Thank u!!! 🙂
