Activity Forums Adobe Premiere Pro C80 Transcode Playback Errors – Green Screen of Agony
  • C80 Transcode Playback Errors – Green Screen of Agony
    Posted by Erin Polich on August 20, 2025 at 4:02 pm
    Hi everyone,
    I have a weird problem here.
    When I import my transcodes of Canon C80 footage into my project, I am unable to playback certain clips. Each time I double click to play the clip in my source monitor, I get an “Error retrieving frame 204 at time of 09:25:44:02 from the file, substituting frame 203.” Then the yellow media loading image pops up in my source monitor before the frame turns green. Some files remain green for playback while I can hear the audio and others allow playback but turn green when paused. They’re all taking a while to load when I try to watch them – disrupting my workflow just enough to be annoying.
    This is only happening with the C80 footage I have and with seemingly random clips (the first 3 might play fine but the rest green out).
    I tried making new transcodes as H.264s (the originals were Apple ProRes LT), but the problem persisted. I tested the transcodes in Resolve, which plays them back fine. I tested on a different computer with the same Premiere version (Mac Studio 2025, Apple M3 Ultra, Sequoia 15.5) and the clips play normally. Lastly, I tried creating a new project with only the C80 clips, but there was no change in the issue.
    The computer I am on is a Mac Pro 2019, 3.2 GHz 16-Core Intel Xeon W. When I first noticed the issue I was on Ventura 13.6.9 for the OS and I updated to Sequoia 15.6 when the Mac Studio played the clips back fine. The problem was not resolved by this.
    My questions are: Has anyone else run into this issue and have they found a solution?
    *Note: I blocked out the folder naming of the files in the error image for NDA purposes.*
    Mads Nybo jørgensen replied 1 year ago 2 Members · 1 Reply
    August 21, 2025 at 4:54 pm
    Hey Erin,
    What version of Premiere Pro are you using?
    And, Apple ProRes LT is highly compressed as a format. Is this what you originally transcoded to? Or is this what was the original source format from the camera?
    What happens if you don’t do the transcode?
