Activity › Forums › Maxon Cinema 4D › C4D(R19) > MAYA(2020) Export
  • C4D(R19) > MAYA(2020) Export
    Posted by Sonny Angell on March 7, 2020 at 12:02 am
    Hello!
    My primary 3D program is MAYA I do not know C4D enough to finish this project thru.
    I am trying to export all animations / meshes from C4D to Maya. Which I can easily do by exporting an FBX or an ABC. However I seem to have some deformers affecting the mesh (beating heart).
    What is the best way to bake everything (including mesh deformers) and export?
    I have tried: Select all item in objects pane > Show Tracks > Bake Objects / Export.
    But It seems one or two parts are made up of lofts or mograph doublers.. so they wont export thru.
    Do I really have to set a “Point Cache” tag for each mesh part? store / calculate or is there an easier way?
    Sonny Angell replied 6 years, 6 months ago 2 Members · 2 Replies
  • Brian Jones
    March 7, 2020 at 5:31 am
    I think Alembic should export your deformations
  • Sonny Angell
    March 9, 2020 at 5:49 pm
    Hi!
    You’re correct it does! Some small issues but I can work around em’ thank you!!
