Activity Forums Maxon Cinema 4D C4dD Select a Certain Object from the reflection
  • C4dD Select a Certain Object from the reflection
    Posted by Maria Pixamins on May 27, 2015 at 8:02 pm
    Hallo I need some help with the reflections in Cinema 4D.
    I have scene and already exluded a certain oject with an object buffer so I can change its color in After Effects.
    The problem is that this object is seen by reflections so I need to have this object mask in the reflections too!
    To be sure I am clear… What I need is a mask from of certain object as seen by reflections.
    Jordan Quackenbush replied 11 years, 2 months ago 2 Members · 1 Reply
  • Jordan Quackenbush
    June 8, 2015 at 3:51 pm
    If I understand what you need, right-click the object in your Objects window, go to CINEMA 4D Tags, select the Compositing tag. One of the options will be “Seen by Reflection” – uncheck that.
    8904_screenshot20150608at11.48.30am.png.zip – if it helps.
    Jordan Q
    If I’m posting a question, it means I’ve Googled it for far too long and couldn’t find a solution/answer.
