Activity Forums Maxon Cinema 4D C4D Version 13 Workspace Blacked Out, Objects not visible.
  • C4D Version 13 Workspace Blacked Out, Objects not visible.
    Posted by Karl Gambino on August 18, 2012 at 1:51 am
    Just got a copy of this software installed it. Everything is fine in loading, and it updated correctly. Problem I have as the title implies is that I have no visible workspace, no grid, no visible objects. I’m curious if anyone else has experienced, and hopefully has a fix for this issue. Thanks
    Thunder Waffe replied 13 years, 11 months ago 3 Members · 5 Replies
  • Brian Jones
    August 18, 2012 at 2:23 am
    in Preferences/OpenGL try turning off OpenGL. If you get your interface it’s probably your drivers/card otherwise I don’t know.
  • Karl Gambino
    August 18, 2012 at 2:37 am
    Okay, I will try that. Thank you. I just installed the latest drivers for my video card, that didn’t help but hopefully the culmination of the 2 will work. Thanks Again
  • Karl Gambino
    August 18, 2012 at 2:39 am
    Thanks very much, that worked perfectly.
  • Brian Jones
    August 18, 2012 at 2:42 am
    Turning off OGL means you are using software rendering not the graphics card at all, depending on your card/system sometimes (from what I’ve heard) the latest drivers are not always the correct ones. Some of the guys here will know more about PC graphics cards and the drivers you need to be running (or perhaps Maxon support) but they’ll need to know what the card is and what version of the OS you’re on etc.
  • Thunder Waffe
    August 18, 2012 at 3:03 am
    Try deleting your preference folder. If that doesn’t work, update your driver.
