Activity › Forums › Maxon Cinema 4D › C4D V2023 Render Queue Does not pick up where it left off when stopped
  • C4D V2023 Render Queue Does not pick up where it left off when stopped
    Posted by Michael Goldberg on April 19, 2023 at 2:15 pm
    No doubt V25-v2023 have added a lot of great tools, but I hate running into things that have worked for years, and all of a sudden they don’t. Part of the game I guess. Anyway, I noticed rendering in the render queue (v2023.2) once I stopped, the queue did not pick up where it left off.
    Previous versions were great with that. Anyone see this?
    Mike
    Shahid shahan replied 3 years, 4 months ago 3 Members · 4 Replies
  • Shahid shahan
    April 23, 2023 at 4:58 am
    It’s not uncommon for new versions of software to have some changes or issues that affect the workflow, even if the changes are intended to improve the software overall. As for the issue you mentioned with the render queue in Maxon Cinema 4D v2023.2, it’s possible that the software may have changed the way that the render queue works or that there may be a bug or issue with the current version.
    To troubleshoot this issue, you can try the following:
    1. Check the render queue settings: Make sure that the render queue settings are configured to save the current job list when you stop rendering. To do this, go to the Render Queue settings and check the option to “Save job list when render stops”.
    2. Try rendering a new job: If the render queue is not picking up where it left off, try rendering a new job and see if the issue persists. This can help determine whether the issue is specific to the current job or a more general problem with the render queue.
    3. Contact Maxon support: If the issue persists, you can reach out to Maxon support for further assistance. They may be able to provide additional guidance or help identify any bugs or issues with the current version of the software.
    https://www.maxon.net/en/support/.
  • Boston Cainfra
    April 27, 2023 at 11:15 pm
    Hello Michael
    There have been lots of lagging issues reaching me on the new versions of redshift
    Incase you’re having similar problem of it not run properly
    I think we all need to tweak some settings on our PC to make it run better
    You can follow these steps below
    1. Verify that the render queue settings are set up properly so that rendering can continue from the last frame rendered.
    2. By deleting the “preferences” folder in the Redshift directory and restarting Cinema 4D, you can reset the
    3. Redshift preferences.
    Redshift Render should be reinstalled to ensure a clean installation.
    4. If none of the suggestions above work, get in touch with the Redshift support staff for additional help.
    THANKS
  • Michael Goldberg
    May 3, 2023 at 5:14 pm
    Thank You, still troubleshooting. I don’t see Render Queue settings either in the render queue or in preferences. I looked everywhere for that checkbox, and don’t see it. I’m not using Redshift on these projects.
    Mike
  • Shahid shahan
    May 4, 2023 at 6:34 pm
    Hey mike,
    One possible reason could be that the Render Queue settings are not enabled or visible by default in your current version of Cinema 4D. In this case, you may need to access them through a different method, such as using a third-party plugin or script.
    Shahan🙂
