Activity Forums Maxon Cinema 4D C4d UV texturing – Scale up in Y-axis only
  • C4d UV texturing – Scale up in Y-axis only
    Posted by Deborah White on September 22, 2012 at 4:22 pm
    I’m playing around with UV mapping and have managed to map my texture.
    However it is a bit squashed along the y-axis. Does anyone know how to scale up faces in the uv texture window?
    When I select scale it scales up the faces equally in the x and y.
    Deborah White replied 14 years ago 2 Members · 2 Replies
  • Adam Trachtenberg
    September 22, 2012 at 6:48 pm
    There’s a separate scale tool for unequal scaling of UVs. It’s called the non-uniform scale tool and you’ll see it if you click and hold on the scale tool in the BP UV Edit layout.
  • Deborah White
    September 22, 2012 at 6:58 pm
    Doh…It seems really obvious now that you have told me how.
    Thank you very much, I was getting frustrated looking for it.
