C4D to AE shadows help
Howdy, I’m new to C4D and I need help figuring out shadows between C4D and AE. I have C4D 10.5 and AE CS3. The scene I’m working on is a simple house sitting atop a piece of blueprint paper with lights casting some shadows. I need to composite the blueprint paper in AE because information on it will need to change between versions. My problem is keeping shadows on the ground plane. If I turn off the plane but try to use compositing tag settings to keep the shadows, etc, I have no luck. It seems like I should be able to get some sort of shadow channel out of C4D but I can’t. Any ideas?
