Activity Forums Maxon Cinema 4D C4D tile camera?
  • C4D tile camera?
    Posted by Andrew Marshall on March 29, 2010 at 9:07 pm
    I used to have the tile camera options under c4D 9. I am running 10.5 right now, and there is no library item for the Tile camera. Can someone point me to it? I am a registered C4D user, I have installed the goodies, and just cant find it.
    -A
    Carmen San diego replied 14 years, 5 months ago 5 Members · 4 Replies
  • Jeremy Allen
    March 30, 2010 at 12:34 am
    I’ve only started using C4D at R11.5 so I’m not sure exactly what you are talking about, but in 11.5 there is a “bucket sequence” where you can basically split up the render into different sections which would be re-assembled in post. Kinda sounds like what a tiled camera would do..
    Hope this helps.
    8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.6
    C4D 11.5
    AE CS3
    FCP 6.0.1
  • Nolan Scott
    March 30, 2010 at 7:15 am
    Open the Content Browser / Presets / Cinema 4D / Misc / Tiled Camera…
    Drag the Tiled Camera into the viewport…
    Drag your Scene Camera into the Reference Camera window…
    Choose your Tiles per Axis (for 4 tiles leave it at 2) / enable Use Tiling…
    Open the Render Settings / Frame Range choose Manual /
    e.g. for 4 tiles choose Frame Range from 0 to 3….
    Make sure the Tiled Camera is selected and activated…
    Render your Scene…
    Regards
    Nolan
  • Navarro Parker
    January 10, 2011 at 7:53 pm
    Just stumbled across this post on an unrelated C4D Google search.
    You might find this helpful when using the Tile Camera:
    https://forums.cgsociety.org/showthread.php?f=94&t=808343
  • Carmen San diego
    April 19, 2012 at 9:51 am
    Anyone knows where to find the tile camera preset in cinema r13?
    thanks
