Activity Forums Maxon Cinema 4D C4d shut down when starting rendering
  • C4d shut down when starting rendering
    Posted by Audis Huang on August 4, 2017 at 7:15 pm
    Hey guys, I have encountered an annoying problem that my c4d shut down without hints everytime when I start rendering a specific project. But other projects stay cool. I have no idea that which setting I might have mistaken in this project can cause such problem..
    Audis Huang
    Audis Huang replied 9 years, 1 month ago 2 Members · 5 Replies
  • Adam Trachtenberg
    August 4, 2017 at 10:36 pm
    Does it generate a bug report? You can check by going to the prefs folder listed at the bottom of the C4D Preferences dialogue. There should be a bug_reports folder there. Check the date/time of the files, if there are any. If there are, send them to Maxon tech support and they may be able to tell you what the problem is.
  • Audis Huang
    August 5, 2017 at 2:40 am
    Thanks mate, unfortunately it seems that there are no such files.
  • Adam Trachtenberg
    August 5, 2017 at 3:55 am
    So much for the easy way. Anything in particular different about this scene compared to your usual files?
  • Audis Huang
    August 5, 2017 at 4:14 am
    i thought that was cause by the settings, but actually it occurs again when i copy all the objects to a previously work project. Thus i think it
    might be some problems in these objects, but there is no difference from my previos, no plugins. The file of the project is even way smaller then others, only around 1000 KB.
  • Audis Huang
    August 5, 2017 at 5:27 am
    i think i just find the problem. It works after i disable some groups that contain multiple objects. But i wonder if it’s normal for c4d to crash if there are some complex parent relation between objects to be rendered?
