Activity Forums Maxon Cinema 4D C4D Selction Error!
  • C4D Selction Error!
    Posted by Rack Chan on October 2, 2010 at 6:10 pm
    OMG! I read about this damn thing, but nobody can help.
    Simply put.
    My cat stepped on my keyboard while in C4D.
    And now, no matter what, and I mean what,
    I can no longer SELECT ANYTHING. The only way to do so is to click in the list box to the right.
    If I try to click on a model, nothing, if I try to deselect something, it won’t work.
    If I try to right click, nothing, if I try to left click and bring up a menu, in won’t happen.
    I can do everything else so long as it’s not in the 3d viewer. All my mouse functions disappear once enter it.
    The only thing I can accomplish, when I right or left click and drag, is to scale my model, even if I don’t have the scale model tool on.
    It’s literally stuck on permanent scale.
    Please help me.
    No matter what I do, it will open like this for every project, new and old.
    Thanks.
    Rack
    Cory Petkovsek replied 15 years, 7 months ago 5 Members · 4 Replies
  • Thomas Rickenbach
    October 2, 2010 at 8:43 pm
    I had a similar problem a while ago. I tried everything and one day I just got so annoyed that I pressed every key on the keyboard and that did the trick.
    If it doesn’t I’d make sure the keyboard itself isn’t defective (for example that the r key isn’t stuck).
  • Tim Shetz
    October 2, 2010 at 9:04 pm
    You could also try to delete your C4D preferences. That should reset everything when you restart Cinema.
    __________
    Tim Shetz
    c4dtraining.com
  • Adam Trachtenberg
    October 3, 2010 at 3:27 am
    Sounds like a key is stuck.
  • Cory Petkovsek
    October 4, 2010 at 11:02 pm
    Ask the cat to step off of the keyboard. 😉
