Activity Forums Maxon Cinema 4D C4D scene file will not open after adding PBlurp
  • C4D scene file will not open after adding PBlurp
    Posted by Jacqueline Dessel on April 2, 2009 at 4:30 am
    I have a Cinema 4D file that will not open after I experimented with some settings in the PBlurp node. I raised a parameter from 100 to 1000 and it immediately quit and crashes C4D when I try to open it. I’m trying to find a way to extract everything from the file except the Xpresso… is that possible?
    I need the logos and textures that are in this file for a rush project, so there’s important stuff in there… but I can’t keep the file open long enough to delete the Xpresso that I think is causing the problem.
    Is there any way I can fix this file?
    Jacqueline Dessel replied 17 years, 5 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    April 2, 2009 at 5:24 am
    Sounds like you’re probably running out of memory. Any chance you can try and open it on a machine with more RAM? Other than that, you might call Maxon tech support and see if there’s anything they can do.
  • Jacqueline Dessel
    April 2, 2009 at 5:30 am
    Thanks for the reply. I sent the file to Maxon through their tech support page, hopefully I’ll have a solution tomorrow. Unfortunately I don’t have access to a machine with more RAM, so maybe Maxon can open it and delete the PBlurp stuff. I’ll save it out without it and then save another that I can try again.
    Thanks again for the help.
