Activity Forums Maxon Cinema 4D C4D resetting progress
  • C4D resetting progress
    Posted by Maria Vahuri on April 29, 2014 at 1:38 pm
    I have a small issue with my C4D, it keeps resetting my progress while i’m working with it and even when i save and reopen during progress it has reset.
    Saved file preview, this is how it should be
    and this is how it turns out each time
    Can anyone please help me with it. Thank you
    Maria Vahuri replied 12 years, 4 months ago 2 Members · 4 Replies
  • Brian Jones
    April 30, 2014 at 2:30 pm
    impossible to know what’s going on without knowing more about what it is you are doing with the coin/medal thing.
  • Maria Vahuri
    April 30, 2014 at 2:43 pm
    Hi Brian,
    I am simply stacking the coins on top of each other, no animating
  • Brian Jones
    May 1, 2014 at 12:54 am
    if the image of the ‘single’ coin is really all the coins in one spot and you are taking them and stacking them up but then if you play the timeline or save and reopen the document and they go back to the ‘single coin’ then you must have set a keyframe for the coins (or maybe just the first coin but it got copied when you copied the coins). If you are not animating you won’t need the keyframe so just remove it.
  • Maria Vahuri
    May 5, 2014 at 8:11 am
    Thank you so much Brian, that was exactly the problem. You’re a life saver 😀
