Activity Forums Maxon Cinema 4D C4D renders first frame of an image sequence on a material
  • C4D renders first frame of an image sequence on a material
    Posted by Tormi Kadak on September 16, 2015 at 9:34 am
    I have a problem with rendering an image sequence on an object.
    I have converted the video footage into a jpg image sequence and presseed calculate under the material animation tab.
    But when I apply the material onto an object and hit rernder, it only shows the first frame.
    I have gotten this to work before, but it seems to work at random. For example i did the process before I actually motion tracked the video and it worked fine, but after i motion tracked, it started to show only the first frame.
    Same thing goes for it, when i motion track first and them make the material.
    As I mentioned before I have done this process before and it worked just fine, but not anymore.
    Could it be some sort of checkbox that I clicked by accident?
    I am working on PC, C4D r16 studio.
    Sorry for bad English
    Tormi Kadak replied 10 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
