Activity › Forums › Maxon Cinema 4D › C4D rendering for After effects problem
  • C4D rendering for After effects problem
    Posted by Brion on September 19, 2005 at 2:43 pm
    Hi all
    I’m rendering out a little animation to be imported into after effects. The animation has lights on solids which are casting shadows against a wall. Problem is when imported into AE i get bad strobing and rainbow effects when played back.
    I’m rendering in C4D with the sorenson video 3 codec for PAL setup in AE
    Any help would be great as i dont have much time to sort this out.
    Brion replied 21 years ago 2 Members · 2 Replies
  • Lennart Wåhlin
    September 19, 2005 at 3:36 pm
    Use no codec (none or animation) or better render to pictseries ( tga, psd etc.) when rendering out of Cinema or you loss all quality.
    Do your thing in AE, save to lossles again and if on Mac do the codec using QT-Pro, else do the codec with AE in parallel with the no-codec. (That way AE render both at the same time. See AE docs how to do that.)
    Cheers
    Lennart
  • Brion
    September 19, 2005 at 4:52 pm
    Thx for the help Lennart
    OK always render lossless, i’ll give it a go
    thanks again Lennart
