Activity › Forums › Maxon Cinema 4D › C4D Rendering + AA
  • C4D Rendering + AA
    Posted by Seth Baron on June 29, 2011 at 7:16 pm
    New to the forum, thank you for providing this wonderful service!
    I’m new to C4D (very new), so hopefully my question is a simple one to answer:
    I’m trying to render a project without all the “jaggies”. I’ve gone into the settings and turned the min & max AA all the way up to 16×16, there’s no difference. The project is basic, non textured, straight alpha channel, with a sky light. I’m noticing that there seems to be a difference between the active window render (or whatever you get when you hit Ctrl+R) and the picture viewer render. The Ctrl+R version seems to have better Anti Aliasing than the picture viewer’s version.
    I just need some tips on how to fix this, it’s really frustrating! Thanks for any assistance you can provide.
    Adam Trachtenberg replied 15 years, 3 months ago 3 Members · 2 Replies
  • Brian Jones
    June 29, 2011 at 8:21 pm
    the Picture view render is the actual render. Rendering the viewports is a close approximation but AA is turned off as well as some of the generators are by default set to simpler levels (HyperNurbs for example) for speed.
  • Adam Trachtenberg
    June 29, 2011 at 9:12 pm
    Are you viewing the picture viewer render at 100%? It can look bad at some magnifications.
