C4D Redshift Gradients
Hi all, I have an annoying issue with a sweep object, and a redshift gradient I have applied to it.
Essentially the caps of the sweep aren’t following the gradient as per the rest of the sweep (screenshot 1).I tried putting this into a VOLUME builder, which kind of worked, but then I can’t get the gradient to display in the same way (see screenshot 2). I don’t know Redshift that well so am a bit lost!
Would appreciate some support 🙂
Jimmy
