Activity Forums Maxon Cinema 4D C4D randomize TP shader
  • C4D randomize TP shader
    Posted by Raul Velazquez on September 10, 2010 at 5:59 pm
    I have a TP emitter that divides its particles between two splines and I would like to give the particles on each spline a color so one is green for example and the other is orange. I would like to stay using TP and not have to switch over to MoGraph and the Random Effector and all the Jazz with Multi Shader.
    Adam Trachtenberg replied 16 years ago 2 Members · 1 Reply
  • Adam Trachtenberg
    September 10, 2010 at 6:37 pm
    If you have one particle group for each spline you can simply use separate pShape nodes for each particle group.
