Activity › Forums › Maxon Cinema 4D › C4D R17 – RealFlow plugin v1 (1.0.2.0096) – Render problem. Fix?
  • C4D R17 – RealFlow plugin v1 (1.0.2.0096) – Render problem. Fix?
    Posted by Per Sverre wold-hansen on January 9, 2017 at 3:30 pm
    Regarding: RealFlow Plugin to Cinema 4D (The internal C4D UI) – Not just RealFlow import module.
    System: Win10 – C4D R17 (R17.055) – RealFlow Plugin: V1 (1.0.2.0096)
    I’m having issues with renders from the new C4D plugin from RealFlow. The plugin otherwise works fine.
    I’m caching the flow-animation – However, there are frames being repeated
    when rendered. From what I can tell the cache data seems to contain an uninterrupted flow.
    Please check the render output (collected in MP4 container in AE – from single frames.) –>
    About 5MB
    https://secure.logmein.com/f?00_43v9ec6HmiQyuDG1xOCvp5bHAJyf7qIqifglxE8d
    What gives?
    Best regards
    Per Sverre Wold-Hansen
    Fredrikstad – Norway
    woldha@gmail.com
    Joan Masoli replied 9 years, 5 months ago 2 Members · 1 Reply
  • Joan Masoli
    April 27, 2017 at 2:46 pm
    Hey!
    I had the exact same issue. The solution? very simple, just switch to physical render and will solve the problem.
    thanks
    https://www.laconic4d.com
