Activity › Forums › Maxon Cinema 4D › C4D R17 Facture Obj with Delay Effector – Exporting external comp tag problem
  • C4D R17 Facture Obj with Delay Effector – Exporting external comp tag problem
    Posted by Chris Keller on April 19, 2016 at 9:55 pm
    Have a laptop that opens up. I placed the screen and upper screen model in a null. I adjusted the axis point at the bottom where the hinge is to open the laptop up. I placed this in a Fracture object with a Delay effector to give it some spring as it opens.
    I then have an external comp tag on the screen so I can replace with a desktop image or video I make in AE. However, no solid is exporting out. So I started digging more and as soon as I place the screen in the fracture object null thats been animated it turns white. When I pull out its back to normal.
    I have the effector mode set to straight. I use factured obj to allow for effectors to react to basic, non mograph animations. I’ve done this many times before, but I’m not sure I’ve tried to export a screen to AE.
    So I’m doing something very wrong here. appreciate any help. ty
    Chris Keller replied 10 years, 5 months ago 1 Member · 1 Reply
  • Chris Keller
    April 20, 2016 at 12:46 am
    I imported the c4d proj and used cineware to extract and the external comp tag worked. I’ve never used this workflow. is this a glitch or are they phasing out the aep process?
