Activity Forums Maxon Cinema 4D C4D plugin that’s equivalent to Modo’s render passes?
  • C4D plugin that’s equivalent to Modo’s render passes?
    Posted by Ellis Waddell on July 30, 2021 at 1:29 pm
    Modo user here. Might be switching to C4D soon. However Modo has one feature that I use a lot that C4D doesn’t seem to have.
    Modo has a “render pass” system that does not render multiple outputs for compositing. It is used to control channel values in the scene, save those channel values, and render a image sequence of each set of saved channel values. This is very useful for rendering products that have a lot of different color variations, attachments, ect.
    Is there any plugin equivalent for C4D that can do the same thing?
    Thanks all!
    Scott Thomas replied 5 years, 1 month ago 2 Members · 1 Reply
