Activity Forums Maxon Cinema 4D C4D passes needed to reconstruct the “beauty” pass using additive compositing technique
  • C4D passes needed to reconstruct the “beauty” pass using additive compositing technique
    Posted by Nick Barber on February 17, 2017 at 8:45 pm
    Which multi pass renders do I need in C4D to create a beauty pass using the additive compositing process?
    This can be done in VRay but I’m not sure of the render passes needed in C4D to reconstruct the beauty pass.
    Additive Compositing Technique: combining – Lighting+GI+Reflection+Refraction+SSS+Selfilum+Specular (everything is in an Add blend mode in Ae) this create the beauty pass.
    -Nick
    Nick Barber replied 9 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
