C4D Object Buffer Problem
So im rendering a scene with multipasses, AO, GI, Object buffer and so on. And when i preview the different layers in the rendering in cinema, all the layers are there and everything is the way its supposed to be. However, once i import the files into after effects, all layers except the object buffer is there..
I’ve tried this with multiple scenes, with both R15 and R16 and i keep getting the same problem. There just is no Object buffer file.
Any solution to this problem?
