Activity Forums Maxon Cinema 4D C4D NetRender Problem! confllciting IP addresses.
  • C4D NetRender Problem! confllciting IP addresses.
    Posted by Aftab Asghar on November 15, 2010 at 6:44 pm
    Hello Experts,
    I just build a NetRender farm, having 3 machines. 1st Machine has Mac OS and has the sever and 1st client installed (Wireless: ip address: 192.168.1.4 and port 8080)
    The 2nd machine is also a Mac OSX(Wireless: IP: 192.168.1.7 and port 1080) and has a client intsalled.
    The 3rd one is windows OS(Vista home premium) attached through Ethernet (Using DHCP automatic IP) with the 2nd machine(Mac OSX) accessing internet from the 2nd machine. I changed the port on the windows netrender client(from 1080 to 1081) so the server can read it as a separate client even though its accessing internet through the 2nd machine)
    the NetRender server on the first machine recognizing all three clients.. and list it. but when i press render only 2 machine renders, although it list the 3rd(desktop) client and allocated some frames to it but it never renders.
    My problem is: If I connect the Windows Vista machine with the 2nd machine(Mac) in series, it appears in the list but never render(Yes i deactivated the firewall on vista), but if i attach it to the server directly with Ethernet, where server is accessing the other machine through Airport, i can’t have the same ip for both Ethernet and Airport, if i do that Ethernet work but the Airport can’t access the internet and can’t connect the other machines in the local network(wireless), and If i don’t then i have to have 2 separate ip addresses for Ethernet and Airport which is fine but now I can only render on one IP (either Airport machines or Ethernet machine).
    What should I do? What is the Fix?
    All machine has NetRender r12 clients and the server has r12 too, studio version.
    Please help
    Thanks in advance
    Aftab
    Aftab Asghar replied 15 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
