Activity Forums Adobe After Effects C4D Multipass onto AE
  • C4D Multipass onto AE
    Posted by Joao Monteiro on October 5, 2012 at 10:13 am
    Hey guys,
    I’ve done this a dozen times before, but I really don’t know what I’m doing wrong.
    I’ve setup my render in C4D doing render tests etc.
    I’m rendering a 134frames multipass sequence, but for some unknown reason when I’m importing the AEC file into after effects it is only importing the last frame, and the camera as also only 1 frame.
    The camera doesn’t have any movement, so that won’t be problematic, the only thing that is bothering me is that my external compositing nulls are not moving (they only have 1 frame length as well).
    Do I need to wait for the render to be completed? I’m pretty sure I’ve been working in After effects while rendering.
    My output path says all frames, so I don’t understand why it’s only showing up 1f.
    I can replace footage for the whole sequence for each multipass but in the end my ext compositing nulls won’t move.
    Any ideas?
    Thanks a lot,
    joao Monteiro
    Joao Monteiro replied 13 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
