Activity Forums Maxon Cinema 4D C4D Lite/AE Render issue
  • C4D Lite/AE Render issue
    Posted by Angel Nieves on January 10, 2020 at 12:40 am
    I’m using c4d Lite in Ae, but that forum doesn’t have a lot of activity, so I posted my question here.
    My object in c4d is a box with graphics on each side. I don’t have a light in the scene, just using the default scene ambient light. When I rotate the box, the light changes on it, especially on the front. It becomes too bright and faded when turned to that side. Though I am not animating in cd4. I’m doing the animation in Ae, using an Ae camera to add a slight rotation to the box.
    When I animate the box to rotate it, once it reaches the front of the box, I get that bright, faded lighting.
    Before it turns to the front, the image is correct.
    Weirdly, when I have the Ae/Maxon renderer setting at Standard (Draft) instead of (Final), I don’t get that weird lighting. I only get it when with the setting Standard (Final).
    I’m using the Centered Comp Camera in Ae, which seems to default to that front of the box that is overlit.
    I tried adding a light in c4d to the box. The lighting changes so that one side is completely black, but that change is not reflected in Ae. I still get the same rendering.
    I need help figuring out the best way to make the lighting even on all sides of the box, either by doing something in Ae or c4d.
    Angel Nieves replied 6 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
