Activity Forums Maxon Cinema 4D C4D lite objects and/or textures not loading properly in AE
  • C4D lite objects and/or textures not loading properly in AE
    Posted by Orion Mccaw on March 12, 2015 at 6:26 pm
    Hi, I’m fairly new to C4D and 3D animation in general but I have been using after effects for some time now.
    I’ve created an animation of the earth rotating with clouds, an atmosphere, and city lights on the dark side of the earth. When I bring it into AE, however, the clouds and lights don’t seem to be loading when I select ‘standard(final)’ as the renderer in the Cineware effect. I’ve also tried rendering out a short section of the animation as a PNG sequence and still nothing. Another example of this is if I add a sky to my shot in C4D it won’t show up in AE.
    Basically the scene renders differently in C4D then it does in AE.
    I’m using the most current versions of both software.
    Anyone know what I’m doing wrong? Is this some kind of limitation of C4D lite?
    EDIT: I managed to fix the issue. I did a bunch more searching around and found that someone else had a similar issue. I was able to fix it by going into the C4D file and then chose “save project with assets”. then imported that project file. I guess it’s a glitch in AE where it can’t find some of the textures unless it’s all saved together like this.
    Lucas Schwartz replied 7 years, 7 months ago 5 Members · 4 Replies
  • Mike Mackenzie
    July 30, 2015 at 7:01 pm
    This helped me out, thanks for posting
  • Monika Zidaell
    February 22, 2017 at 12:14 pm
    Hi, i had the same problem, but it didn’t help to save the file as “project with assets”.
    What helped thou, was to make editable the problematic layers, in my case — all paths with the extrude effect. Once the shape was editable, the texture loaded fine in After Effects.
  • Evan Morris
    March 28, 2017 at 6:00 pm
    “What helped thou, was to make editable the problematic layers”
    Monika, what do you mean by this? Can you explain how to do this, please?
  • Lucas Schwartz
    February 6, 2019 at 8:40 pm
    Monica to make something editable in C4D you have to click the button highlighted on the image.
    Regards,
    Lucas
