Activity Forums Maxon Cinema 4D C4d Lite afx cant see reflections from hdri?
  • C4d Lite afx cant see reflections from hdri?
    Posted by Emmet Reddy on September 27, 2013 at 7:44 am
    Hi All I’m working for a company using c4d lite and after effects cc its all working ok except when i throw in a sky and a hdri to use as a reflection material, it shows up when i render in C4d but won’t show up in after effects cc andy ideas? thanks
    Emmet Reddy replied 12 years, 12 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    September 27, 2013 at 3:15 pm
    Do you have your AE comp set to 32 bits? Not sure if that’s the issue, but it could be since HDRI are 32 bit files.
  • Emmet Reddy
    September 27, 2013 at 9:01 pm
    I just tried that no joy im rendering the old fashioned way at the moment but would like to be able to get it to work if possible maybe its a c4d setting im missing, can you do it on your machine? Thanks
