Activity Forums Zaxwerks C4D import solved, might help you too!
  • C4D import solved, might help you too!
    Posted by Ben Pohl on September 15, 2006 at 12:19 am
    I’ve been using the latest version of C4D, 9.6. And for a week I’ve been trying to import models into zax. It’s been a real brain teaser for me but here’s the solution if anybody needs it:
    In C4D under Edit-Preferences go to Import/Export and then DXF Export. Then select the Export Type to 3D Face.
    This is the one setting under the one format that zax will take from C4D 9.6, i hope this helps.
    Ben Pohl replied 19 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
