Activity Forums Maxon Cinema 4D C4D: How do I split one poly into two?
  • Brian Jones
    June 22, 2012 at 2:41 pm
    there is a command called Split (in the Structure menu in pre-13 versions, I think) which does what you want. Select the polys you want to be in their own object and choose Split. That will make a new object with the selected polys in it but will also leave the original polys in the first object so just delete the selected polys from that object.
  • Shawn Marshall
    June 24, 2012 at 7:29 pm
    This issue perplexed me for a year or so until I found the “Polygon Groups to Objects” command:
    If you have polygon objects that are internally made up of non-connected surfaces (as can, for example, be created using the Disconnect command or from editable, connected ExtrudeNURBS), this command will create a separate object from each coherent group, which will be made Child objects of the original object.
    In R13 it’s under Mesh: Conversions.
    Shawn Marshall
    Marshall Arts Motion Graphics
