Activity › Forums › Maxon Cinema 4D › C4D – Hair – Two different hair materials on single mesh?
  • C4D – Hair – Two different hair materials on single mesh?
    Posted by Rob Milt on June 10, 2019 at 4:29 am
    Is it possible two have two completely different hair materials on a single mesh? I want to use a ‘selection tag’ to use a different hair material on a single polygon of a mesh.
    Jim Scott replied 7 years, 3 months ago 2 Members · 1 Reply
  • Jim Scott
    June 10, 2019 at 6:42 am
    [Rob Milt] “Is it possible two have two completely different hair materials on a single mesh?”
    Yes it is. With the desired polygon(s) selected, simply add hair and it will be limited to that selection. A selection tag will be created for the cube, and the “Link” window of the Hair Object will be automatically populated with that selection. The hair that was first added to the cube will appear everywhere else. You can then modify the hair materials individually.
