Activity Forums Maxon Cinema 4D C4D Flash Movie Clip Equivalent?
  • C4D Flash Movie Clip Equivalent?
    Posted by Dolphbean on November 14, 2007 at 11:47 am
    Hi There,
    I am wanting to animate a planet in rotation. However, i want the planet to rotate constantly throughout the animation.
    I was wondering if there was some way to do this like you would a movie clip in flash, so that once it has reached one full rotation it would simply start from the begining again regardless of the other elements of the scene.
    Is this possible?
    Many Thanks
    Dolph
    Dolphbean replied 18 years, 9 months ago 2 Members · 2 Replies
  • Nolan Scott
    November 14, 2007 at 8:01 pm
    Well, animate one rotation of your planet /
    (you might like and set the keys to Linear interpolation)
    open the Timeline / select the planet /
    in the Attributes-Manager set After to Repeat /
    (your object should rotate (loop) now as long as your animation-length).
    Cheers
    Nolan
  • Dolphbean
    November 15, 2007 at 12:23 am
    Thanks Nolan. Problem solved!
