Activity › Forums › Maxon Cinema 4D › C4d extrude is hollow
  • C4d extrude is hollow
    Posted by Keith Hall on November 17, 2019 at 12:26 am
    I have created a logo and extruded with sucess but when i use mograph effects the object is actually hollow not a solid object. How can i fix this?
    Jim Scott replied 6 years, 10 months ago 2 Members · 3 Replies
  • Jim Scott
    November 18, 2019 at 5:47 pm
    Hi Keith,
    As I understand it, what you are referring to is simply the nature of C4D. It is not actually creating solid objects, but shells created out of polygons which then give the appearance of solid objects. If you are trying to use deformers like “Explosion” to break apart the extruded logo the result will be that the polygons comprising the shell will be spread apart revealing the hollow interior. If you want to end up with what appear to be solid pieces (though they are still hollow) of your logo moving apart, place your extruded logo into a Voronoi Fracture object and use “Random” or “Push Apart” effectors.
    If this doesn’t help, please clarify what you are trying to do, and/or upload your project file (or a simplified version) so that we will have a better understanding of your goal.
  • Keith Hall
    November 18, 2019 at 7:26 pm
    The example is the this video i used it on.
    https://youtu.be/Vl-sHE1eny4
    Instead of shattering in blocks it explodes the outer side walls and front and back . Hope that mskes sense.
    Keith
  • Jim Scott
    November 18, 2019 at 7:36 pm
    So, just to clarify. You want the logo to shatter into blocks rather than the flat polygons as displayed in the video?
    Could you upload the extruded logo you are using?
    Edit: Or just upload an example of a simple extrusion with the effects you applied to it?
