Activity Forums Maxon Cinema 4D C4D Dynamis rigid body, objects passing trough eachother
  • C4D Dynamis rigid body, objects passing trough eachother
    Posted by Ruud Van gerven on August 30, 2012 at 8:40 pm
    Hello Everyone,
    I’ve made a “simple” dynamic chain setup of 4 chains connected to a single torus. One end of every chain has a rigid body [Static Mesh] attribute. All other shackles including the torus have a rigid body [moving mesh] attribute.
    Once i press the play button, the dynamics start and also the problem :p. A few shackles won’t stay in line and pass trough the others, destroying my chains. There’s no issue with the position of the initial state, none of the objects intersect. It’s probably to heavy for c4d, wich is pretty anoying.
    Can u guys help me with this issue? I’ve allready played arround with the project settings, chaning the steps per frame but that didn’t help.
    Grtz Ruud
    Ruud Van gerven replied 13 years, 7 months ago 3 Members · 3 Replies
  • Brian Jones
    August 31, 2012 at 12:47 am
    chains are possible but touchy to get the settings right and the scene too – there has to enough space in the links of the chains so the links don’t start too ‘tight’. Here are some examples, the first chain with nothing attached works mostly because of the steps per frame and the solver iterations, the second adds an object at the end of the chain but only works (for me anyway) if I reduce the mass of the object by a lot, the third as another way to do the same kind of thing with a spline with spline dynamics on it but it’s not as ‘real’.
    4607_dynamicschains.zip
  • David Patterson
    September 11, 2012 at 2:03 am
    Brian – Thanks for posting the examples and explanation. Very informative!
  • Ruud Van gerven
    January 4, 2013 at 10:55 am
    Thanks for your reply and example file Brian! I had to go for the spline dynamics option because i had to much shackles to get it to work with normal dynamics. The steps per frame and the solver iterations did make a difference but couldn’t keep up with my scene.
