Activity › Forums › Maxon Cinema 4D › C4D boole not showing up in AE
  • C4D boole not showing up in AE
    Posted by Sandy Sanchez on July 10, 2019 at 2:36 am
    hello, I am having trouble with cinema 4d and after effects (I am using c4d r20 demo).  I have created a boole rectangle which hides some cylinders and in C4D it works just fine.  but when I save and try to view the effect in After effects it does not update.  The cylinders show up in the after effects project as if they weren’t being affected by anything.  I’m assuming there are render settings I have to adjust in order for a boole effect from C4D to show up in AE?  How do I get the boole effect created in c4d to show up in ae?
    this is how I have it in C4D
    this is the ae project, without the boole effect showing up
    this is the hierarchies I have set up.
    I am new to c4d so any input would be so helpful. thank you!
    Sandy Sanchez replied 7 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
