Activity Forums Maxon Cinema 4D C4D basics
  • C4D basics
    Posted by Paul Ullah on January 8, 2010 at 10:43 pm
    I’m very new to C4D. In fact I’m very new to 3D so forgive my lack of basic knowledge.
    I am creating a model from a Cube and chose 4 segments in X,Y and Z so that I could rough it out really quickly without having to select a couple of dozen faces for every maneuver. Now that I have the basic shape I want to add more detail and therefore more segments.
    how do I increase the number of segments after I have made my primitive editable?
    Randy Johnson replied 16 years, 8 months ago 3 Members · 6 Replies
  • Nolan Scott
    January 8, 2010 at 11:07 pm
    Well, select some of your faces (polygons) or select all…
    Go to Functions / Subdivide / choose your Subdivision and click OK.
    Regards
    Nolan
  • Paul Ullah
    January 9, 2010 at 2:12 am
    Thank you very much!
  • Randy Johnson
    January 9, 2010 at 3:09 pm
    If you need so many faces to work on perhaps you may want to try modeling with hypernurbs.
    Here is a great starter tutorial that will help you with many of the modeling tools and show the most common approach to modeling in cinema. Its free but you need to to sign up.
    /Randy
  • Paul Ullah
    January 10, 2010 at 6:00 pm
    Strange that you should suggest that. I am trying that out at the moment.
  • Paul Ullah
    January 12, 2010 at 3:01 am
    How do I import a jpg to use as a reference image?
  • Randy Johnson
    January 12, 2010 at 8:15 am
    While in a flat view (right or top) press shift V and you will get your view options, there is a place there to load an image.
    /randy
