Activity Forums Maxon Cinema 4D C4D background image is distorted
  • C4D background image is distorted
    Posted by Michael Becke on July 12, 2010 at 11:44 am
    Hi guys,
    I’ve looked high and low for a solution to this simple problem and no luck.
    I’m adding a backgound image so that I can composite some text onto it in C4D but it get’s squashed.
    The image is 2592×3888.
    So it’s portrait and when I import it, it just get’s squashed down. Where do I change the settings in C4D so that I can see the image at the right aspect ratio?
    Many thanks,
    Michael
    James Grubb replied 15 years ago 2 Members · 1 Reply
  • James Grubb
    September 15, 2011 at 11:04 pm
    HI an answer two years later. You need to set the render viewport size to the same size as the image you are using for the background material
