C4d Arnold Render issue Material not Showing
Hi very noob question,i’m using the explode deformer to make an object appear on the scene, the problem is that the material doesn’t appear…when i remove the deformer the material comes back.Did i miss something? i switched back to the Standart and Physical renderer and the materials are showed with the deformer, it’s a kind of issue with C4D Arnold renderer.
Any help will be useful.
Thanks Guys
Ps: i hope i’m not posting at the wrong section.
