Activity Forums Maxon Cinema 4D C4D / Arnold missing plugins?
  • C4D / Arnold missing plugins?
    Posted by Sonny Angell on March 22, 2021 at 8:34 pm
    Hello!
    I am working on a project that someone else created, this person used Arnold as their renderer. When I open the project files I get this error (image)
    All the materials start to disappear and turn grey on all materials as the project opens.
    And it seems some rigging issues come up too,
    Jim Scott replied 5 years, 5 months ago 3 Members · 2 Replies
  • Justin Thomson
    March 23, 2021 at 3:39 pm
    You’ll need to get an Arnold license.
    Arnold Renderer | Autodesk | Arnold for Cinema 4D Plug-in
  • Jim Scott
    March 24, 2021 at 1:37 am
    You should be able to just remove all of the Arnold materials (and Arnold lights, etc.) and replace them with standard C4D versions, and also remove “Arnold Renderer” from the project’s Render Settings. You can then resave the project and the error message shouldn’t return if you’ve removed everything associated with Arnold. Arnold is only a renderer, so it should have no effect on rigging. That issue is something you’ll need to fix on its own.
