Activity › Forums › Maxon Cinema 4D › C4D AND AE
C4D AND AE
Posted by Carlos Angulo on November 24, 2006 at 8:36 pmHi everyone,
I’m a new guy at C4D, but I want to learn everything about C4D and after effects integration, I havenAdam Trachtenberg replied 19 years, 9 months ago 2 Members · 2 Replies -
Carlos Angulo
November 25, 2006 at 7:10 pmI got to install it, but when i try to import a project, nothing happens, no error, nothing, what am I missing?
Adam Trachtenberg
November 27, 2006 at 4:55 pmFirst, you need to copy the appropriate AE plugin from your Maxon>Exchange Plugins directory to your AE plugins directory. Then, in Cinema’s render>save settings you need to check the appropriate options (“compositing project file>AE”, and if desired “3d data”). Then click the “save” button, which will prompt you for a location to save the *.aec file.
Open the *.aec file in AE. The plugin will take over and import your footage, multi-pass passes (if specified in Cinema), 3d data (if you applied 3d data tags in Cinema), cameras, lights, etc.
Some tutorials (a bit dated, but you can probably figure them out):
https://www.creativecow.net/show.php?page=/articles/thorn/c4dtoae1/index.html
https://www.tvgrafx.com/tutorials.html
https://homepage.mac.com/komaruyama/Tutorials/AE/index.html
